AMR Trainer 26 - (my) official build thread
#351
My strapping of choice is Velcro Plant Tie from Lee Valley. Hard to beat at $3.95 for a 30' roll.
I'm a fan of the Smart Fly ignition cutoff with its fibre optic connection. Here are the transmitter and receiver with foam and platforms.
Platforms glued in.
Transmitter and receiver strapped in place.
Platforms glued in.
#352
Measuring the length for the fibre optic cable.
I've been thinking for some time about the screws for the fuel dot... they've got sharp points (as screws tend to have) in close proximity to wires and fuel lines.
My first step was to remove each one and round off the edges on a grinder. This large hemostat holds them securely for the job.
That's a good start. My next step will be to cap them with heat shrink tubing.
#353
Graphics for the plane (designed in MS Visio, exported to .jpg). Note that the small graphics on the bottom row will not all be used in this build.
I've made my own in the past using waterslide decals but this time I decided to try a custom vinyl order. I'm going with Callie Graphics - I've heard great things about them and if the quality matches the service and the price I will be mightily pleased.
#356
Had a few minutes in the shop last night. The first thing I did was install the Gold'n'Rod outer tube through the firewall. This marks my first use of epoxy in this build.
I noticed the drool after I took the photo and yes, I did clean it up.
View from the inside (it's a very short tube).
Next up was the choke rod installation. After remounting the engine I slipped the cowl onto the fuselage to get a look at the choke arm and its 4-40 ball link from outside.
Cowl off and choke bracket on.
#357
Time for the throttle linkage. My tried-and-true method is Sullivan Gold-N-Rod with a ball joint on the throttle arm.
I tried to use the two nuts to thread the rod into the socket but that didn't work out, so I clamped the threaded rod between soft jaws in the vise and the socket in some pressure-sensitive locking pliers. That worked fine.
Gold-N-Rod cut to length with the servo end rod threaded in.
Throttle linkage installed.
#361
Up early this morning for a couple of hours in the shop. I worked on the pull-pull rudder today. I have a nice straight length of coat hanger wire that's good for pulling cable and I started by feeding it through the cable guide from the back.
When the rod was through I taped it to the cable.
Pulled through.
I stuck a piece of tape on the cable to stop it from slipping through the cable guide.
Pulled through.
#363
On to the elevator servo. Given the shape of the elevator and the location of the servo, the linkage will have to be angled. This threaded rod shows maximum deflection of the servo end ball link.
I considered mounting the horn on the same line but I think two ball links would be better.
I suppose I could put an S-bend in the push rod too. Are the other approaches? I'd like to hear them.
#365
1. Relocate the elevator servo up so that the rod is more of a straight line to the elevator horn in the vertical direction.
2. Move the horn on the elevator inboard, and closer to the hinge line so that the angle in the horizontal direction is not as extreme.
Just MHO. Good luck
Sincerely, Richard
#366
Two things I would do:
Just MHO. Good luck
Sincerely, Richard
Just MHO. Good luck
Sincerely, Richard
#367
Wonderful photos and even better story telling.
I've been following your build from the beginning, thanks for sharing!
Regarding your Futaba receiver, it appears both antenna leads are on the same horizontal plane. Have you considered installing one of the antenna leads vertically and the other horizontally while still maintaining the 90 degree angle rule? I'm curious if there is a reason for your setup (carbon fiber obstruction, lack of space).
I look forward to your final posts and can't wait to hear of your maiden flight. The trim scheme is awesome.
Thank you.
Clear skies
-PD
Thank you.
Clear skies
-PD
#368
Thank you.
Clear skies
-PD
Thank you.
Clear skies
-PD
#369
Elevator linkage continued...
I picked up longer servo arm for better clearance from the pull-pull cables.
Elevator clamped.
Elevator horn installed, carbon fibre tube cut.
Linkage complete!
I'm confident that there's no interference between rudder and elevator linkages but because I can, I cycled the rudder and elevator with a servo tester to be sure.
[YOUTUBE]http://youtu.be/ABtOnE3bGEw[/YOUTUBE]
Elevator clamped.
Linkage complete!
#370
As always I will install some guide tubes for the low- and high-speed carburetor needles. This time I'm trying something new, starting with some grip rings on the tube. Stay tuned for more.
Except for the batteries, all of the electronics and in and connected. I will tidy it up later.
This was accomplished with the help of a wiring diagram I put together for another project. It's nice not to have to look everything up.
#373
A little time early this morning dedicated to the carb needle guide tubes. I tune my engines while they're running and I like an easy way to ensure that the screwdriver stays on the needle.
In the past I've found that Sullivan Gold-n-Rod tubes fit over the needle screw heads, like on the DA 50...
Not so in this case, so I'll be butting the tubes to the face of the screws. Hence the epoxy on the tubes in the post above - they're to give the heat shrink something to hold onto.
The needle springs on this DLE 30 are so close together that I could only get heat shrink over one of them, and that with a struggle. So I made four cuts in the second tube and stuck it on the high speed needle.
Arr, fair be warned, says thee to I - that'll never stay in place. Got a trick for that. First, heat shrink on that tube. Then, heat shrink over both tubes.
Next comes holes in the cowl. As always I start with a brad point bit, turning counter clockwise by hand to cleanly remove the covering.
#374
