AMR Trainer 26 - (my) official build thread
#151
Banned
#158
Thanks, fellas. I used to take my DSLR into the shop for project photos - now I do all that with the camera on my Samsung Galaxy S4.
#159
Step 77 specifies installation of the gear with 6-32 bolts and blind nuts. This would work if installation of tank try F10 back in step 10 hadn't covered up inside access to the front holes. No sweat; I have another tried and true method at hand: #10 wood screws.
Drilling the holes.
Drilled, threaded and drizzled with CA.
Step 78 directs the builder to use socket head cap screws as axles. I prefer the spring steel Du-Bro models so I drilled out the axles holes to 5/16" to accommodate them.
Landing gear mounted.
Drilling the holes.
#160
I had some 4" wheels in the shop so I'm using those instead of the supplied 3-1/2" wheels.
I also don't like the supplied tail wheel bracket so I'm going with a Great Planes model that I've used before.
I figured that the tail wheel arm would benefit from a third hole - here the location is marked.
Hole drilled.
Hole drilled.
#161
On to the empennage. Back in the first pages I cut all the pieces out from 3/8" balsa and glued the relevant parts together. When I got them out again the first thing I did was to go over the joined with a razor plane to knock off any glue and high spots.
The manual makes no reference to the stabilizer leading edges but I've not see square ones yet. I clamped the horizontal stabilizer in the vise - GENTLY - to work on it.
The very first pass with the razor plane.
Nicely rounded.
Nicely rounded.
#165
#166
The rudder one of the rudder hinges is supposed to go in the rear of the fuselage. Not going to happen until I fill this gap.
This was a piece of 3/8" balsa but I've planed it to thickness. The notch is for the part of the tail wheel bracket screw that sticks out. Why didn't I just remove the screw and re-install it afterwards? Damn good question!
Just the right depth for a hinge point.
Glued in place.
Glued in place.
#169
Time to make the hinge holes in the vertical stabilizer and rudder. I marked across the trailing edge of the stab where I wanted the hinges to go and made sure the line was visible through the Robart centring jig.
Drilling the hinge point holes.
When all of the holes were drilled I put these 1/8" blind hole spotters in place.
#171
Banned
I would add a U shaped 1/8 inch metal piano wire epoxied along the edges that goes a good inch toward the trailing edge of the elevator.
Zor
#175
There are servo bays at the back of the fuse and I plan to use two elevator servos there.
The dowel is a backup in case the plane is too tail heavy and requires a single centrally located elevator servo. If that's the case then I'll consider your suggestion, Zor. If all goes to plan I will separate the dowel halves.
Thanks, fellas.
