blind nut or threaded ply?
what is the preferred way to hold a wingbolt to the ply support? A blind nut, or threading the ply? The ply support is 1/4" and for the bolt I was planning to use a 1/4 bolt. The plane is a .60 warbird.. thanks
I always drill and tap hardwood mounting blocks, but use blind nuts in plywood. If you are using birch plywood, then you are probably fine with drill and tap too, but if you are using poplar "light ply", then I would definitely use a blind nut.
