Retracts on an Old Kit...??
I have an OLD piper tomahawk kit (.60 size) that I finally decided to build. To make it interesting I decided to add a set of mechanical retracts that a friend gave me. The kit IS NOT designed for retracts, but I can make the modification needed for the retracts. The question I have is how will adding retracts to a plane not originally designed for retracts change the flying characteristics? This will be my first experience with retracts so any tips will be greatly appreciated. Thanks!!
My Feedback: (60)
AZ
Assuming their is not an excessive weight gain associated with the retract installation then I think the performance would, if anything, be better. It may not make much difference at all really but I certainly don't see any reason why it would negatively effect the performance in any way. My .02 cents of course.
Should be a great project. I've been using the Spring Air retracts for years with absolute success. See if they have anything that fits your design. Dan.
http://retracts.com/
IN
A flight instructor I had called it the Trauma-hawk......... apparently, the wings could blank the t-tail during high angle of attack manuevers and create a very sporty situation.
Wow...In that situation I'm sure that name is justified.
Well anyway, my retract addition has been scratched. I actually don't have enough room for the main gear to retract all the way into the wing. I need the airfoil to be about a 1/4" thicker. I was really looking forward to it....but oh well.
