TF Elder Byplane plans >
Old 10-18-2016 | 03:19 PM
Sharpeye22's Avatar
Default TF Elder Byplane plans
Can anyone supply me a copy of the plans for the Elder Bipe, are at least full scale drawings of the interplane struts. I picked up a built one at an estate sale but it does not have the interplane struts. (The ones out on the outer part of each wing.). I would perfer the plans of course because there is a lot of information on them I might need as I put this plane into flying status. But If you have the plans or you have one built I would be thankful if you could trace the struts and send it to me.
Old 10-19-2016 | 08:39 AM
foodstick's Avatar
You might try digging thru this site. http://www.outerzone.co.uk/index.asp
Mount the wings on your plane,then take some cardboard and make a template that fits on top of the bottom wing and up against the bottom of the top wing. Once you get this to fit nice..take your time. Then you can slide it out to the missing strut locations, and it should be the right dimensions. mark where your mounting points on the wing touch the carboard template.Then draw lines representing the strut sticks on the cardboard.. you have a perfect pattern !
