Hammer.40+ YS.60 build
#52
My Feedback: (209)
Center section is glassed and built up area underneath the wing is complete, tasks like this take as much time as building a wing and aren’t real glamorous. What is glamorous is all up weight under 4.5 pounds with all construction completed. I will most likely fall under 6 pounds flying weight. It is almost time to get the covering scheme figured out…….I think my vertical performance will be pretty good............
RICKSTUBBZ (01-19-2024)
#58
while covering is probably the most tedious part of building a plane, it can certainly be the most rewarding...
then again, I have manged to make a couple nice airplanes ugly in that last stage.... covering..
Your "HAMMER" is coming along "NICE"
It's come along very quickly.
That is something else I have never been able to do - get them done in a reasonable amount of time.
#59
My Feedback: (209)
I would have probably had it done except we got a couple snow storms and I'm the snow removal guy.
This one is going to come down to the final pieces of eye twist covering, pin stripes, and graphics.
I think I can make it look ok, I actually let someone else pick the colors on this one..............................
#63
My Feedback: (209)
Rick,
I always enjoy you coming and commenting, ALL comments and thoughts are welcome.
I think you were thinking the same thing on the Olympic Challenger thread.......
My stuff is always going to be different than most..........Some works out good and some works out GRRRRRREEEEAAAATTTT!
#67
I see you are an early bird also...
Dang, I just looked, at 1st post... You'll have this thing from box to runway in a month..
I got to tell you - seeing you build this thing as well as the others has me motivated to get this plane I have been tinkering with done. I really want to get covering.. but there are still several little issues to fix before I can cover. I did get the wing measured out and adjusted.. Now I have to glue on the permanent wing saddle shim.
#70
My Feedback: (209)
Well the engine and pipe are mounted, tail weight added (2oz) and it feels pretty light. I’m right at 5.5 pounds with 3 servos, switch, and battery to go. Should come in right at 6 pounds, a little more than I wanted but still pretty decent. Prop is an 11-9 and depending on rpm’s I can get, speed will be between 129 and 145 mph. Hard to say for sure, but maintaining 125 should be no problem and that was my goal………. Graphics next……
TheEdge (01-22-2024)
#72
My Feedback: (209)
Here is the plane pretty much done, also “Dez” the little gal that picked the colors got to see it for the first time today and she likes it. So feel free to let her know if you like it or hate it……….
Total time from opening the box to now is 17 days, I'll wrap up now with final balancing and radio installation........
Thanks for checking it out!
Dave
Dave
#73
Great Job Dez,
Now, are you going to get some stick time too? If not on this one maybe something a little slower.
Heck, maybe you are already an experienced RC pilot and can put this speedster through it's paces?
#75
My Feedback: (209)
Took the Dez-Mobile outside to see if the natural light helps the colors. Seems like the lighting makes it look different. I’ll be able to see this thing just fine at 125 mph and for me, that is what it’s all about…………😉
