GP 40 size CAP
Sounds like you want it real heavy. Are you trying to build a plane for speed trials, or display? This plane needs to be less than 5 lbs RTF. If you sheet it with 1/32 and glass it with 1/4 oz it may be light enough. If you don't glass it, I don't see any reason to sheet it. Is it for asthetics only?
No....
Too heavy...
Mine is powered by a .61 MVVS incowl muffler
with one servo for ailerons and on board glow
and still have marginal vertical performance....
It is covered totally with monocote, make sure
that you beef up the landing gear..!
Cheers
Hisham.
Too heavy...
Cheers
Hisham.
I covered mine with monokote and it weighs 4.5 lbs. Monokote is also really easy for repairing.
In the second landing the undecarriage snaped. I put a 5mm plywood instead and now it's unbreakable.
haven't wieght mine yet, but it's lighter than the gp .40 extra.
like firebolt said...i don't think them big cut out holes at the front
of the fuselage is such a hot idea. i did re inforce , but i think i'll
keep those pieces in the next time i build 1 of these again.
without Eq/ engine it would around 4.5lb ..?
WA
If you sheet it you might want to glass it. Get a custom paint job on it. Dang that would be sweet. Put something with some ponies up front. Cafeen man has a site that has directions on how to glass. I wouldn't sheet just for strength. If you crash it doesn't matter if it's reinforced the nth degree.
CT
This plane needs to be light not a lead weight!!!!!! Oh my god if u glass it and paint it it would weigh like 7-8 lb holy crap!!!!!! Mine only wieghs 6 even with lightened stuff, bigger holes in fuse, no balsa blocks, no sheeted canopy area, no sheeted wing tips mini receiver, and mini throttle servo!!! Geeze guy if u wanted to glass a plane buy a foam combat plane!!!!
Josh
Josh
Mine feels light but prolly weighs in at about 3 kgs or 6 pounds. Its a strong stif airframe without any additional sheeting. I would imagine a 70 -80 FS motor would give good vertical peformance. On the landing gear issue - all you need is to change to 5mm plastic bolts. They break before the plane or ali gear does if you flare a tad late. I've already tested mine[8D]
ON,
nope, build them light (under 6 pounds for sure) and the plane is awesome, mine will do anything i want. No bad snapping or tipstalling from what ive seen of mine.
Tom
Tom
ON,
I have a Webra 50 on it, the plane has unlimited vertical at half. it needed an ounce of weight up front with the rudder servo in the back but i will eliminate the weight when i put a replacement fiberglass cowl on it.
Tom
Tom
RV, that Webra sounds awesome. My OS 50 seems to be running better and with a 13X4 APC .It seems to have the right kind of power for the plane. Its a great plane - very smooth flying and yet highly aerobatic. Snap rolls are extreme and she spins nice and flat. Landings can be as slow as you like - my last was a full stall 3 pointer at walking pace with no tip stall tendencies. I have removed all lead from the nose and she really floats in now.
Mine are pretty much per the manual - she rolls fast despite the small ailerons. One of our clubs pattern pilots had a go and got a tad nervous because of the sensitivity of the controls - and there I was thinking the Cap was a smooth easy flying plane!
ON,
i moded mine for 2 inch built up airlerons they move about 1/4'' on high rates and the roll rate is really fast. Low rate is about an 1/8 inch or so.
Tom
Tom
My Feedback: (16)
AE
I love my GP's Cap 232, been flying solid for almost 3 years, would love to build a new one (this one has a lot of hours on the airframe). I put an O.S. .70 in it, have unlimited vertical (pulls like a tractor) with a 13-5 (high altitude) or 14-5 Zinger prop (close to sea level), with this pitch prop it will still haul hiney (gets weird though at higher speeds, it loves to fly slow). If I build another one, I would install the rudder servo up front with the others (had to add weight to the nose, even with a 4-stroke up front) and hook it up as a pull-pull system. The landing gear has been my only problem with this kit, ripped it out 3 times, the last time it came out I glued the block back in with probond and it hasn't budged since. Oh yeah, go with a fiberglass cowl, the ABS cowl requires too much work to make it look good. I have one servo for the ailerons and it rolls quite fast, have expo dialed in to damper it a little. Finally, this plane is too short coupled to do 3-D (it's a handfull to do a harrier) without a lot of fight (except for some of the tumbling type aerobatics). My plane weighs 5.25 lbs, stock built out of the box, with no attempts to make it lighter. There seems to be a huge inconsistancy with the balsa densities used to make these kits.
