Need help woth Venture 60
My Feedback: (21)
I am about to put the top sheeting on, the long piece over the fuel tank, instrument panel etc. My problem is that I am unsure of how this piece goes on. Is the sheeting supposed to hang off of the sides? Do I trim it? Does the sheeting taper down toward the engine cavity and then flatten out? Any help you guys can provide would be great..
IL
Yes. It hangs over the edge. If you look in figure 37-38 you can kind of see it hanging over. Just sand it down even with the sides when you have it all glued up.
Kerry
Kerry
