Repair Question
AL
Repair Question
While practicing my crosswind landings Saturday, I ran my LT-40 off the side of the runway. Our runway has a slight shoulder and the plane would not easily return to the runway. I was hesitant to run the throttle up enough to jump it since the plane was pointed at the pits and I didn’t want to take a chance of it getting away so I waited till all was clear, walked out to the plane and gave it a push on the vertical stabilizer. Well, when I did I heard a slight pop[X(]. Upon further investigation it appears that the stab joint has popped loose on one side only from the leading edge back about 4 inches. I thing I can get some thin CA up under the joint and maybe some medium. Or, should I remove it completely and re-glue the joint?
Mike
Mike
GA
RE: Repair Question
Mike,
This is a herd one to be definitive on without seeing the damage, however, I would try the thin CA first, so long as you can get a tight joint with the stab to fuse. If this is not possible, or the thin CA does not work, then "no harm-no foul". Remove the stab and re-glue the whole assembly with epoxy.
AL
RE: Repair Question
Thanks everyone. I actually cut out and shaped the tri-stock to put around the vertical stab when I built it but decided not to use it on the advice of my instructor. I have many many flights on this plane without incident. Just wasn't thinking when I grabbed the stab and pushed.
