 sig's 4*40 >
sig's 4*40
sig's 4*40
Old 01-06-2004 | 03:14 AM
Default sig's 4*40
Is this kit a laser cut kit?
Old 01-06-2004 | 06:55 PM
onytay's Avatar
Default RE: sig's 4*40
The 60 size is, so I would think the 40 would be too
Old 01-06-2004 | 08:04 PM
.40 size is, at least the one I built this last summer was
Old 01-06-2004 | 08:51 PM
Thanks for the replies! What about the Great Planes easy sport 40? The reason I ask is I am looking for a second plane but I want to try a laser cut kit this time, my trainer was die cut and I wanted to compare them.
Old 01-06-2004 | 08:59 PM
JNorton's Avatar
Greenbean,
Try the 4 Star 40. It is laser cut. It is also a great flyer. I used Hitec 425 servo's in mine. In the wing I used the large red servo arm and have about double the control throws. I also cut a wing bay off each side. It still floats on landing. I'm using a TT .46 Pro with an 11 X 6 MA prop. I cut 3/4" off the front of the canopy to remove the bubble look. You can also use a Somethin Extra canopy. Great flyer. You will like it.
John
Old 01-06-2004 | 10:54 PM
My Feedback: (27)
4*40 is great to build and fly. is great 2nd plane. Gary
Old 01-07-2004 | 06:50 AM
JNorton's Avatar
GreenBean,
This is the color sheme I did mine in. The pilot is a green mouse. I flew 6 gallons of fuel thru it this summer. I really - really like it.
John
ID:	88404   Click image for larger version
ID:	88405   Click image for larger version
Old 01-07-2004 | 11:54 AM
John, Thanks for the pics. It really looks good, I was looking at the kit at Tower Hobbies and they said it requires a .30 to .40 engine, but I have a os .46 fx that I could put in it. do you think this engine would work well with this plane? What do you have in yours? Thanks for the help.
Old 01-07-2004 | 03:51 PM
JNorton's Avatar
Greenbean,
A .46FX would work great. I have a Thunder Tiger .46 Pro in mine. I like an 11 X 6 prop. I have use an APC 11.5 X 4 and it worked well also.
John
