Scarf Joints good or bad?
WI
I'm currently building the Dare Wright Flyer. For the wing, LE, TE, and spar the plans call for them all to be scarf jointed. I was going to my LHS today anyway, and I think they have balsa thats long enough to use w/o making scarf joints. My question is: Is there a reason that he calls for them to be scarf jointed? Does it matter either way? Does scarf jointing make it any stronger?
Thanks in advance!
Joe
Thanks in advance!
Joe
ND
RE: Scarf Joints good or bad?
I'm guessing the scarf joints are made to accomodate 36" balsa but I dont' know what your wingspan is, so can't say for sure. There's nothing wrong with a properly done scarf joint. It'll be just as strong as the surrounding wood, and actually its a good way to transition from a spruce spar to a balsa spar on the outer wing, where spruce isnt necessary.
WI
OK. Scarf joints it is (besides I have no choice, I didn't know until today that balsa came only up to 36", I'm still a bit new to building kits). Anyway I was just curious, and now I know I don't have to worry about it.
Thanks to everyone for replying!
Joe
Joe
Community Moderators
My Feedback: (42)
You can buy balsa in many different lengths. Look at http://www.lonestar-models.com/ and their standard balsa inventory. Most balsa is cut 36" because the logs are shipped into the states in this length, or very slightly longer. Few hobby shops carry anything other than 36 because 48, the next standard length, is considerably more expensive and fewer people need material that long.
But, as the others have already said, a scarf joint is completely acceptable.
John
John
FL
You can get balsa up to 48". Maybe longer, but I've never seen it. I wouldn't scarf joint it unless necessary to make the extra length. If you think you need to for additional strength, but can use one piece that is long enough, then maybe laminate a thin piece of plywood to the stick where the scarft joint was. Without seeing the plan, it's hard to say exactly why they have you doing this. I'm guessing it's just for length - not for strength.
WI
Thanks! I'm going to give it a shot now, going by the plans. I have a little miter box with cut outs for different sized wood, so I should be fine (famous last words ).
Thanks again to everyone!
Joe
Joe
FL
dustoff - NO! Don't use a miter box. YOu want that joint to be longer than you can get with a miter box. Just stack one piece over the other and then cut your angle. They should match up perfectly.
WI
I finished the first wing last night. Here's a pic The scarf joints came out just fine. Thanks again for all the help. Greatly appreciated. I have a building question, but I found the designers email address (hopefully its still good).
Joe
Joe
WI
Hi CafeenMan,
So far it doesn't bother me too much. I was thinking of unscrewing it for this project, but space is limited in our apartment. So keeping it together is easier. My "work table" isn't too heavy either. Plus I have to put everything away at night. 2 kittens & 1 cat. Its just over the wing anyway. As you can see my "work shop" is the living room. My wife must really love me At least I can paint on the back porch, but not really enough room to build, and its cold back there. Anyway, the bottom wing is next. Thanks for the nice comment
Joe
PS I visit your site fairly often for hints & tips. Its Great Thanks for that too!
Joe
FL
DustOff - I split mine into two pieces because it didn't align well enough to make a one piece wing anyway. I would like to replace that aluminum square piece with a nice piece of seasoned hardwood.
Movers broke both of the stands, so I made new ones from 3/4" pine. I made them so I can clamp them to the table or bolt them. That way they're easily removeable.
Thanks for the compliments ref the website.
What kit is this that you're building?
WI
Oh its the Dare 1903 Wright Flyer. Compliments well deserved
FL
Do you have a link for Dare? I've been wanting to build a Wright flyer for a while now. I have scale drawings, but I'd rather build from plans or a kit than design it myself. How scale is it? Mine will be more for display than for flight so I want it to be scale. If it doesn't fly ever, that's ok by me.
WI
Here's their web site. [link=http://www.darehobby.com/index.html]Dare Hobby[/link] I bought mine from my LHS, that's closing. Its "fairly well" scale. I saw a couple of pics that people have built. And the box pic look pretty good. He also has a suggestion to get the paper covering to look realistic.
The instructions say to add all the scale detail you want from a pics of the real thing. They just show minimal rigging. I've read posts where people have flown them. I guess they fly fairly well. I don't know if I'm going to fly mine yet. I may be too chicken to
Cover both sides of the flying surfaces using "Skyspan" tissue & dope. Once the tissue is watersized, apply 3 coats of nitrate dope. This system is the most authentic natural linen look I've seen yet
