Balsa Nova Throws
My Feedback: (54)
Splais,
The Morris Hobbies Balsa Nova .40 "ARF" manual lists;
Ailerons: 3/8" each way
Elevators: 5/8" each way
Rudder: 3 to 3-1/2" each way.
Use these as your low rates and increase to your taste for high.
The CG is 4-1/2" from the front of the wing/belly pan.
I checked an old BN .40 kit I've got and the manual says to refer to the plans. I checked the plans;
Ailerons: 15* each way
Elevators: 13* up and 15* down
Rudder: 42* each way
* = Degrees
The CG on my plan measured exactly 4-9/16" from the leading edge back. They state to balance within 1/4" of this mark.
I hope this helps you.
* = Degrees
