Astral Hog
If you have built an Astral Hog by Sig from the kit and plans please contact me here. I need some technical information about the correct angles of incidence for the wings and tail feathers and line of thrust of the engine.
I have had two responses so far but I'm not sure it is a good idea to raise the back of the engine (using washers on the rear engine mount bolts) in order to lower the thrust line of the engine and not adjust the angles of incidence on the wings and tail. Balanced on my incidence meter the wings measured a -4' and the tail feathers (elevator) a +2.
Any help with this will be appreciated.
Thanks Glen
Thanks Glen
