 Aligning V-tail >
Aligning V-tail
Aligning V-tail
Old 04-02-2004 | 12:57 PM
Default Aligning V-tail
I'm almost finished with my winter project - a Skybench Cloudbound4 sailplane. I'm at the point of attaching the V-tail to the fuselage. The problem I'm having is how do I align the V-tail relative to the wing? I've tried measuring the distance between each wing-tip and the tip of each half of the V (like I've done for the more conventional tail), but I'm not sure if that's the best method - everything looks pretty symetrical, but I'd hate to just eye-balling the alignment. Any ideas?
Old 04-02-2004 | 04:22 PM
My Feedback: (90)
Default RE: Aligning V-tail
put your V tail upside down on your workbench. Put the fusealage on and level it on your work bench. So now you have both the v and the fuse upsidedown and leveled. Put a straight piece of wood accross the rear of the fuse. Measure up from the bench to the wood that it is the same on both sides and glue your stab . You'll find this is the easiest method of doing it.
Dennis
