 Goldberg Extra 300 Kit Question >
Old 05-13-2004 | 04:10 PM
bckyrdbshr's Avatar
My Feedback: (35)
Default Goldberg Extra 300 Kit Question
I am fixing to start building a Goldberg Extra 300 It will be lightned to the max without compromising the strength of the structure. I have a foam wing kit for it that will be cored a set of carbon fiber gear glass cowl and pants and maybe a carbon fiber spinner. Ok heres my question I dont want to cut my cowl all up so I want to run a inverted 4-stroke (I dont mind cutting the bottom of the cowl). I want the plane to have unlimited verticle i'm not into 3-D just your normal airbatics and some Imac. I dont want the plane to be under powered and I dont want it to be way over powered. I also want to run a 3-blade prop for the scale look (I know the 3-blade is not as efficent as a 2-blade but that dont bother me) I'd like to hear some suggestions on engine prop combos.
Old 05-14-2004 | 12:19 PM
LuvBipes's Avatar
Default RE: Goldberg Extra 300 Kit Question
Saito 150 (180 guzzles too much fuel and there's not much room for a 24 oz tank in this plane), YS 120/140.
Keep the plane under 10lbs and any of the above engines will give you unlimited vertical.
Old 05-14-2004 | 02:26 PM
bckyrdbshr's Avatar
My Feedback: (35)
Thank's for the reply LuvBipes.... anyone else care to add any other suggestions.
Old 05-18-2004 | 10:27 PM
THE SAITO 150 IS A POWERHOUSE IF MONEY IS NO OBJECT I WOULD GO WITH IT . I DONT HAVE ONE BUT HAVE HEARD GOOD THINGS ABOUT THE 150.
Old 05-20-2004 | 07:20 PM
With YS 120 you need to put ele & rud servos in the tail, , as well as the battery, maybe with the new YS 110 you may get some weight advantage; I am sure power will be there!
Also I did reinforce the fire wall and the landing gear fuselage former.
You will get what you are looking for with this combo.
