Pneumatic Retracts or Servo? Your two cents, please!
Ok, this is for an ARF but no matter because I redeemed myself by buying a Sig SE kit last weekend
I have NO experience with retracts and my H-9 P51 comes with servo activated retracts but I plan to change these out with something from Robart. However I can't decide on whether to install pneumatic or servo activated and was hoping to read your comments on the pros and cons of each?
Many Thanks
Flying Scotsman
Many Thanks
Flying Scotsman
I've had good luck with mechanicals. simple, reliable, no leaks, easy to install. Biggest con imo is if for some reason, the gear get stalled (eg. bend a strut on takeoff), you could be stalling the servo to depending on how you've set it up
Sorry, no experience with pnematics, but others here obviously have! As some would say, six of one, or half a dozen of the other.
cheers,
-E
cheers,
-E
The Retracts that I use are mechanical ones that I designed and machined back in my days as a CAD/CAM designer for a Govt. machine shop. They are basically the same as most of the commercial jobs, but I use 3/16 wire, and they have the added feature of an internal over-center spring which makes them move effortlessly and therefore work easily with a standard servo.
But, I didn't like the non-scale appearence of the standard servo (FLIP, they're up and FLIP, they're down) so I invested about $55 for a 180 degree retract servo. I don't even bother with the over-center spring anymore, and I just love how they go up and down so smoothly! And unlike the pnumatics, I can use them as many times as I like per flight, and they NEVER leak air!
Originally posted by JohnVH
FWIW, on a 10X you can slow down a servo to any speed you like, so on a retract servo you can get the speed you like
Harry
My Feedback: (18)
TN
94739Z Contest Proportional Retract Servo
I have one of the Airtronics 94739Z Contest Proportional Retract Servos that allows you to slow it down with a 10X, Stylus, and possibly the 9Zs. I've never used it, but did play with it a bit before I got rid of my 10X. It works well. You can even set the endpoints, greatly simplifying mechanical retract setup. The cool part was how slowly, smoothly and realistically the 10X would move the retracts. I'll never use it, if anyone's interested, I'll sell it for $50 shipped. They are $69.99 street price. It has the new "Z connector", meaning it is compatible with JR/Futaba, and newer Airtronics receivers.
