 gp cub j-3 need help >
Old 07-29-2004 | 09:08 PM
Default gp cub j-3 need help
when i was joining the two wing halves together the right leading edge came out about an eighth of an inch lower than the left one if u know what i mean. was wondering if theres ne thing i could do to fix this or if it really matters. or if i screwed up really bad then jus tmake me feel better and say that u guys have done it before also. any replies would be greatly aprreciated. thnx
Old 07-29-2004 | 09:33 PM
Default RE: gp cub j-3 need help
How does the trailing edge look?
Old 07-29-2004 | 10:15 PM
waagbuck's Avatar
You'll most likely be fine. Sometimes I think the concern for precision in sport model airplane construction goes too far. Just slap on the engine and fly it!
Old 07-29-2004 | 11:36 PM
Jimmbbo's Avatar
If the right leading and trailing edges are mismatched by the same amount below the LH wing, it's just a cosmetic problem.
If the RH LE is dropped and the RH TE is above or even with the LH TE, then the wings will have unequal incidence. The airplane will fly, but you will have to add left aileron trim to hold wings level in flight, and the left wing will stall before the right one does
HTH
Jim
Old 07-29-2004 | 11:43 PM
no actually the trailing edges are perfectly straight together
Old 07-30-2004 | 02:50 AM
Jimmbbo's Avatar
ORIGINAL: iflyrc0288
The left wing will stall first... Reckon you did a real good job of epoxying the two halves together, so separating them is not an option...???
Cheers!
Jim
Old 07-30-2004 | 12:17 PM
Dano13's Avatar
Not to belittle, but this is why "dry fitting" before gluing is VERY important!
I, too learned the hard way.
Dano13
Old 07-30-2004 | 01:44 PM
If your leading edge is truely only 1/8" off then you have nothing to worry about. The plane will have a very slighty bias in one direction that can be easily dealt with by a couple of clicks of aileron trim. This is a Cub after all not a precision aerobatic machine or high speed jet.
