 Dirty Birdy CG? >
Dirty Birdy CG?
Dirty Birdy CG?
Old 08-27-2004 | 10:35 AM
Default Dirty Birdy CG?
Does someone have the CG for a Bridi Dirty Birdy? Also what is the final flying weight you have come out with? 7.75 is the advertised weight.
Old 08-27-2004 | 03:39 PM
My Feedback: (12)
Default RE: Dirty Birdy CG?
6 1/2" from the trailing edge of the wing at the center.
Old 08-27-2004 | 11:54 PM
I checked it at 6 and half inches and it doesnt come even close. It flys a little nose heavy but that cg and it is way off. can you or someone double check that figure? Also what weight has everyone been getting?
Old 08-28-2004 | 05:08 PM
Balsa or foam wing? Glass or Balsa fuselage? Retracts? Tuned pipe? The glass and foam ones would likely be the heaviest. I've seen a couple over 9lbs. All good wood and a light finish, it should be possible to come in around 8.
ORIGINAL: Sirkaos2000
