Oops, This Cant Be Good...help!!!
I was wondering if u kit veterans out there could help a newb out...
I was using to low of a "grit" and i accidently over sanded the side of the fin on my Daydream glider kit and im not sure how to completely the problem at hand. one side was a "canyon" in the wood with right angles when u look at it from the bottom. I solved this by gluing balsa pieces into the gaps and sanding that side back to the right dimensions.
_______ _______
l_______l
However...
the other side has more of a bowl shaped "valley" that would be diffiult to get balsa to mate with due to its shape. So, what should i do with this side?
_______ _______
\________/
should i try to get balsa in to there anyway, or should i just level out the rest of the fin to match the same width? Any help with this dillema would be greatly appriciated.
You see, this is what happens when your not 100% focused on what your sanding balsa...shame on me
thanx in advance
_______ _______
l_______l
However...
_______ _______
\________/
thanx in advance
TX
can glue a skin of new balsa over the rough area then resand after it dries , I would use gater glue or elmers pro bond, read the directions before using,as it dries it also expands filling in the little nooks and cannies,use sparingley because it will expand.
hope this info helps,John
Thanks for all of the support guys!
I suppose i could make a new fin but there is no more extra balsa in the kit so id have to go and buy more sticks to make another fin.
Ill try to first fill it in with balsa and glue and if that doesn't work then ill cut away the screwed-up portion of the fin and just rebuild that part instead of starting from scratch (so to speak)
I just have one more question... what is considered "balsa filler"?
Is it just slivers of balsa that are CA'ed into cracks or is it something else entirely?
Thanks for all the great advice youve already given me!
OR
There is one company that sells a balsa colored filler, comes in a little (little butter tub" like container, and runs about $5. You can get the same thing in the home improvement department, only they call it lightweight spackle. The container is about 3 times larger, and the price is ...... usually less than $5. Great stuff, waterbased, sands nicely, only available in white though. I think mine was from Red Devil. I'd be tempted to glop some of this in the valley, and the bowl, and then use a putty knife to run over the top of it, and level it up to the sides of the fin. Sand it with a finer grade though
Dan Gellner
Dan Gellner
Al Stein,
It is very kind of you to offer your help like that, however, i live in the Bucks County newtown.
Im just curious though... what "Airplane club/field" did u join? I am planning to join a club when i finish the plane and maybe you can suggest one in PA
If I needed to fill in a low area and wanted it to be stronger
than Spackle and yet still sand easy, I prefer Z-poxy finishing
resin and micro balloons.
This combo works great
Roby
Roby
