Dynaflite Decathlon MAX Prop Size
GA
I'm thinking about trying to put a 2.4 gas engine on a dynaflite Decathlon. What is the MAX prop size I can use on this airplane. The engine I want to put on takes a 20 x 10 prop. It doesn't look like enough ground clearance for a 20 x 10 prop. Thanks for any advice.
IL
Hey there, On my Decathalon I am running a Brison 2.4 and I am using a zinger 18-12 prop outstanding performance with this prop. i could't use 20" prop not enough ground clearance. Try the 18-12 you may like it....Vic Gasparini
