What engine for SE - Saito 56, Saito 72 or Saito 82?
ON, CANADA
I live in hot humid weather (all year around 33C, relative humidity 90%).
Money is not an object. The weight and engine’s versatility for future projects are.
If someone has above mentioned engines weight obtained by digital scales (not from Horizon specification sheets) I would highly appreciate it.
Thanks in advance.
Thanks in advance.
GA
RE: What engine for SE - Saito 56, Saito 72 or Saito 82?
I have a Saito 82 in my SE... I love it. It has huge power. I just wish I had the ability to fly it well. . I am learning and am trying to take it easy with it. I do not want it DOA before I get some use out of it!
LATER
LATER
ON, CANADA
I don't think he is kidding. I have Saito 91 myself - it is 50 g more then 72 and you can run it with 12X6 prop without a problem. But 91 is on another plane. So, 82 weight is not an issue at all, even if it is 100g more on the SE nose , then with 56?
My Feedback: (133)
CA
The 91 weighs about the same as a 65, and lots of folks end up with 4-8 ozs of lead up front. Besides, I only paid $40 for the plane, built with two servos and a switch!
ORIGINAL: submikester
You've got to be kidding - a .91....pictures please.
Seriously...
Seriously...
