Sig 1/5 Scale Cub Landing Gear Source
UT
Sometime back, before a household move interrupted my build of the 1/5 the Sig Cub, I had located a source of an excellent looking articulated landing gear by a Wm. Wallace in Idaho. I book marked the e-mail address "J 3 Gear.com" and was hopeful of ordering same.
The site appears closed now.
My question is two fold: "Does anyone know if this gear is still available and how?" "How about some feedback on other sources? Robart?"
Thanks, Blue
Thanks, Blue
IN
RE: Sig 1/5 Scale Cub Landing Gear Source
Blue:
I too haven't had any luck locating the Wallace gear. However I think towerhobbies.com list a Robart set that they are very proud of. Let me know if you have any luck finding the Wallace gear I read somewhere it was more reasonably priced.
Thanks Kev
Thanks Kev
ORIGINAL: bluebikerblan
Thanks, Blue
Thanks, Blue
There's more--(had to leave and take my older daughter to a Christmas dance)--How the gear attaches is a bit different. The "hard points" of the Wallace gear are connected by straps that go from one side to the other, and 4 screws fasten the whole thing to the fuselage. The "hard points" of the Robart gear are separate, and each takes 2 screws. Makes locating them properly a little more critical for everything to match up, these are one of the parts that are slightly out of scale, but they are a heavier gauge of steel than the Wallace gear, and instead of having screws to carry the main gear struts, they use pins about 1/8 in. dia. with e-clip keepers. The whole plane would collapse before these things would give. The bungee strut bracket is smaller diameter than the area it fits in (Robart), and it needs a shim or sleeve to keep it from moving back and forth about 3/16 in, but no shim or sleeve is included with the Robart set, and this is puzzling, as well built and designed as it is otherwise, but I made some for mine using some thick aluminum tubing about 3/16 diameter. Durability is what will sell the Robart, in my opinion, especially if you occasionally land as hard as I have, but if you can grease that Cub in without bouncing, the Wallace gear is okayand might give adequate service. I'm going to leave the Wallace gear on my L-4 until it's ready to fail, figure I'll get another 100 landings if I'm careful. I'd guess I've got at least that many on them now.
UT
Thanks so much for the comparative information on Robart vs Wallace. Since it seems the Wallace gear is no longer available ???????the Robart gear is our best option (as it may well have been in the first place) as I know of several guys very happy with the Robart set up on their Sig 1/5th Cubs. Really appreciate the detail Kev. Best, Blue
