Painting canopys???
Painting canopys???
I'm coming down the homestretch on a GP Extra 300 kit and have a question about painting the canopy rim. The precautions for LustreKote say it will deform clear plastic butyrates. I assume this is the material the canopy is made of? The manual says to use Pactra Formula-U or Chevron Perfect Paint. My question is does anyone know of a safe paint that closely matches Metallic Red MonoKote? Thanks in advance for any help.
My Feedback: (108)
RE: Painting canopys???
I have to admit that I must have missed that warning. I have been painting my canopy trims for quite sometime with Lustercoat and I have not had any problems at all with any of them. I know that Chevron has closed up shop and I think that Formula U is hardly available. Hangor 9 has released a line of paint that matches Ultracoat. Good Luck, Dave
My Feedback: (37)
I also have used lustercoat on several canopies. I used very light coats and had no problems with distortion or softening of the canopies. I will add however, that I was not very satisfied with the color match between the film and the paint.
Thanks guys, I was hoping to use the LustreKote to get a half way decent match with the covering. If it messes it up, I think it would look better with a new tinted canopy anyway.
One other question, would you suggest painting the cowl or using covering on it.
My Feedback: (108)
By all means spray the cowling. Just make sure that you have a good primer on the cowling and the temp is about 70 degrees. As mentioned, do a fog coat on the canopy as well as the cowling and let it set for an hour or so and then do it again. You may need 5 or 6 fog coats to get the proper coverage. As for color match, it will be close but I am sure that it will not be perfect as they say. The covering was done with one die lot and the paint another. Most all colors of Lustercoat will be a shade or two different. Good Luck, Dave
