 Removeable wing on Dazzler or Uproar ?? >
Old 12-10-2004 | 07:31 PM
Default Removeable wing on Dazzler or Uproar ??
Has anyone modded the Dazzler or Uproar kit so that the wing can be removed - either two piece with an aluminum tube or bolt on type design? I thought either one of these hot little planes would make a good "travel model" with a removable wing. I did a search but did not find such an attempt-any reason this mod would not be a good idea? Flipstart
Old 12-10-2004 | 08:55 PM
Default RE: Removeable wing on Dazzler or Uproar ??
The Uproar .60 has a removable wing,but the wing center 'Device',LOL) is a pain.Wasn't that bad though,i built the plane in three nights,pretty easy.Modding the.40 will require a fuse redesign,constant taper from the firewall to the tail.
Old 12-11-2004 | 08:24 AM
I was mostly thinking about the 40 size-saw that the 60 size had a removable wing-so the fuse on 40 size has a taper in the wing area-that would present a problem-but-for $40 may give it a shot.
Old 12-11-2004 | 08:28 PM
enahs's Avatar
I have two Uproar 40s that both have removable wings (bolt-on.) The first one has more than 100 hard flights on it with no problems and the second one is in the covering stage. If you'd like, I can get some pictures of them tomorrow and post them along with any other details.
Shane
Old 12-12-2004 | 09:00 AM
Shane-that would be great if you get a chance-have some basic ideas but if yours is proven-that is enen better-may build 2 at one time-one for a friend that works all the time. Couple of pics is worth a or 2 thousand words-so they say. Thanks Flipstart
