Tailless senoir telemaster
NC
I recently aquired this almost finished model. The guy who had it said it is a senoir telemaster, but he lost the runner and elevator while moving. Does anyone know the original width, legenth, ect. and if this is indeed a telemaster. I've included a pic. Thanks N4SKL
RE: Tailless senoir telemaster
Thats not a Telemaster,thats a Senior Kadet.You can get the plans from Sig pretty cheap which will give you all the info you need to finish the plane.
NC
Thanks for the replies. I didn't think it matched pics of telemasters I'd found on the net although similar. I'll try contacting Sig for plans. If anyone has dimension's for the tail section or pictures that would be great. Thanks again. N4SKL
A word of caution on the Sig Kadets. From what I have been told by Sig, the rudder and elevator stock is custom made for the plane. This is the case for the Kadet Jr, which I'm collecting material to build, and may apply to the Kadet Sr as well. You may want to check into it if you decide to order a plan sheet from Sig
