TF cessna 182
I am currently building a TF cessna and need some help from those of you that have done this kit. I am going to be sheeting the top of the wing and plan on installing a light kit. I have some tubes to run the wires but I am a little hesitant on sheeting the rest of the wing just yet. I am concerned that when I come back to drill the hole through the wing tip I will miss the rod. I plan on marking the wing where the rod is, but is there anything else I could do??? This is my first kit and I am having tons of fun building it. I have the fuselage about 80% done, and will hopefully be done within the week.
I would also like to know what servos I should go with(I know I should have already installed them, but I couldn't resist building some more), I am a futaba guy and would like to stick with that. I have two spare 3004's and plan on using them. Where??
