Great Planes p-51 Pitts Muffler question
MO
I Recently started on a GP P-51 Mustang and last night bought a SuperTigre GS-51 for it . My Question is the cowl is very small so what brand/type of Pitss Mufflers will fit inside the cowl. The Plans and instruction book show a Tatone strap on pitts muffler. but would rather use a bolt on if I can help it.
RE: Great Planes p-51 Pitts Muffler question
Daryl,
I just saw your post from April while doing an RCU search for "Great Planes P-51". I just finished mine and plan to maiden it tomorrow -- weather permitting.
I had the same trouble you did... my G51 wouldn't fit under the cowl with a Bisson Pitts muffler. I said the heck with it and used a ST swing muffler. It's one of the older, teardrop-shaped ones, not one of the new huge ugly ones.
I just found a Slimline Pitts in the shop that looks like it might have fit in the cowl. I do have a spare cowl so I'll check it out some time when I have the cowl off.
Is yours finished? How's it fly?
Good flying,
desmobob
Good flying,
desmobob
MO
Not done yet but its getting close. Just have to finish the covering. I actually build pretty fast but I have had long stretches where I did not have a chance to work on it. I am using a slimline pitts muffler made for the ST .40-.51 engines it fits but I had to hack the RH and bottom of the cowl a lot to make room for it. Here are some pics that I have made along the way. Good luck with the maiden and let us know how it flies and post some pics if you have them.
ORIGINAL: biton
Here's mine. I've got about 20 hours of flying on her.
Very nice job!
I've been flying mine for a couple of days now. I have it on the workbench right now. I'm changing my engine mount from inverted to horizontal; I didn't like the way the inverted Super Tigre G51 ran with the carb spraybar even with the bottom of the fuel tank. I have a spare cowl and a Slimline Pitts muffler that fits (The Bisson Pitts muffler I have is much longer and would require cutting both sides of the cowl to fit).
Good flying,
desmobob
MI
Have a ST 40 in mine with a Slimline pitts muffler. Had to extend the cylinder head cutout a little to accomodate the muffler but it doesn't detract much and is a great flying machine. I also installed B & D 60 size mechanical retracts. Have around 100 flights on it.
