How to make Z bends?
TX
RE: How to make Z bends?
I'm not sure I can describe this in words very well but here goes. Make a 90 bend in the end of the wire. Grip both parts of the 90 degree bend in the pliers and make the second bend which is not in the same plane as the first bend. Now twist the first leg 90 degrees to make the entire wire in the same plane.
Make sense?
Bob
Make sense?
Bob
Before I bought my z-pliers (which I recommend you to buy) I used to clamp the wire in a wise and use a hammer to shape a Z bend, works pretty good actually!
-First you clamp the wire and make a 90degree angle on the end of it, leaving 1/2 inch.
-Then you release it and clamp the short (1/2 inch wire) and make another 90 degree on that one, done!
(English is not my mother tongue, I wonder if anyone understood my "instructions"? )
My Feedback: (20)
First you take zee wire to be be bent. Zen you take zee pliers zat you are going to use to make the z bend with. You place zee wire in zee pliers being careful to locate in zee proper place to result in zee proper length for zee part you are making. Zen, you bend zee wire to the shape of a z. You cut to length and voila, you have z bend.
Anonymous
Anonymous
CA
dragon....Drive 2 large nails in a board about 1/8 inch apart. Keeping the wire flat bend to 90 degrees. Flip it over and do it again. This is similar to Harry Higley's bending jig. You can put in more nails as you need, a little experimentation and you will figure it out. Hope this helps. Use framing nails, ie. 16d. If you are splitting the board, try pre-drilling the board. Use a doug fir 2 by 4 piece. Some clarification. put the wire between the two nails to bend to 90 degrees, and bend one leg.
