Sig Kavalier CG
QC, CANADA
RE: Sig Kavalier CG
The plans for the Kavalier i'm building now shows the furthest rear CG point to be exactly in the middle of the main spar on the underside of the wing. The furthest forward CG point is 1 inch towards the leading edge from the furthest rear CG point.
Cheers,
Chris.
Cheers,
Chris.
NC
RE: Sig Kavalier CG
On the plans there are 3 CG points noted; I measure 4 3/16 in. from leading edge to Aft most point (center of spar), 3 11/16 to middle CG point, and 3 5/16 to farthest forward CG point. the plans have a note saying to use Fwd most point for Test flight, middle for sport flying and Rear most for aerobatic flying.
Hope this helps, regards, Steve
