Morris hobbies Jerry's Big Boy CG
CA
I am recovering a Jerry's Big Boy. Not the ARF but the kit which I believe they have discontinued. I do not know where the CG is on this plane. I tried a Saito 90 but it was going to take a lot of lead in the nose to balance if the CG is around the location of the main spar. I have a new Saito 120 which is much heavier and would come closer to balance if used. Is this too much engine for this plane? Where should the plane balance. Regards Flybye
