Help with Telemaster Fuel Tank!!
I'm in the later stages of building my first Senior Telemaster. Besides using it to drop candy and take pictures I'm really wanting to use it as a glider tow plane. To that end I'm planning on sorta overpowering it with a Saito 180. Now comes the problem - I'd like to install a 20 oz (minimum) fuel tank so I can get more than 5-8 minutes of flight time but I can't find anything off-the-shelf that will fit in the 4" x 6" fuel compartment. Can anyone give me any help for building a fuel tank or links to companies that have custom built tanks?
Thanks for any leads,
Tim
Tim
My Feedback: (13)
MD
Look at the Graupner fuel tanks at Hobby Lobby. They make some large tanks that fit in smaller areas. Their part #GR238 is 24.5 oz. and is 5 3/4" long by 3 3/8" wide and 2 5/8" high. It sells for $15.90. Hobby Lobby refers to them as 4 stroke tanks.
I don't know how much power is required to tow a sailplane, but I had an Enya .80 4 stroke in my Senior Telemaster and it had a plenty of extra power. A Saito .180.....[sm=eek.gif]
You might be able to tow a Buick with that combo !!!!!
My Feedback: (30)
by the way where do you plan to place your tow line on the mother plane? We did a tow from a
large telemaster from the tail yet i have heard you can pull from the top C/g and also from bottom of plane----any experience on proper location????? Pleas email any suggestions to:
[email protected]
thanks
[email protected]
thanks
