Warped vertical stabilizer?
Hi all, I'm building a 4Star 40. The vertical stablizer is precut balsa sheet and has a good bow to it. is there an easy way to get the warp out? thanks Mike.
NM
I would soak it in water or a 50-50 mix of water and amonia until it is limber enough to bend. Weight it down on a flat surface and when it dries it will be straight.
