 Sig Wonder construction -Help! >
Old 06-19-2005 | 08:21 PM
Default Sig Wonder construction -Help!
Hi,
I am currently building a Sig Wonder. Can someone tell me me which is the top of the wing and which is the bottom of the wing. The instructions are a bit confusing. Is picture 7 in the manual the top or bottom of the wing? What is the orientation of the Wing Dowel Supports (WDS) with relation to the wing. Does the side of the WDS that is flush with the rib edge face toward the bottom of the fuselage, with the part of the rib that is not covered with the WDS is the top of the wing.
Appreciated,
djt294
Old 06-19-2005 | 09:11 PM
Default RE: Sig Wonder construction -Help!
dtj I Have Never Built This Ship.I Would Sugest That You Take The Planes To The Hobby Shop Were You Bough It Or To The Field You Fly At And Get The Help You Need .
At My Local Hobby Shop We Help Folks All he Time.If I Have A Question I Can All Ways Take It To My Friends I Fly With And We Always Figure It Out.Good Luck And Don't Give Up.Nothing Is Better Then Kit Building.
Old 07-08-2005 | 07:37 PM
I built several ..............several years ago .In fact have one in front of me now.
Hummmmmmm .Since its a sym airfoil you will determine the top and bottom of the wing by rear boltplate, drilling of the dowel in the leading edge or the wing tip if you used a horner type......................When it comes to checking CG....make sure it is as to plan (right on the money)! and it's a great flyer if you do. Hope this helped.
Dennis
Old 07-09-2005 | 06:33 AM
MinnFlyer's Avatar
Riley is correct, there really is no Top or Bottom until you add the mounting parts
