What is MonoKote Trim Solvent?
I know what it is, where to get it, how to use it etc, but what is it actually? It's something that activates the adhesive, so is it just a generic solvent like rubbing alcohol? I'd like to get some, but the bottles are so expensive and I'd hate to just pay that much for a branded version of paint thinner. Thanks guys!
Reid
Reid
Monokote Trim Solvent
I have personally never had any luck with the stuff. It could certainly be me but it seems when I put it on then attach the monokote over the other monokote something bleeds and it looks like somebody messed up.
I learned, right here, to use acetone for a cheap cleanup, gets the bleeded color off easily!
I just looked, trim sealant contains, you guessed it, acetone, just tried some acetone on a peice of fabrick and it did indeed activate the glue!
have fun
Roger
have fun
Roger
NC
I've not done a lot of trim work with the solvent, (one plane only) but I've never had a problem with bleeding. The man at my LHS warned me about the potential problem. He said to put the sovent on per the instructions, so light you barely know it is there. The lay the monokote on without shifting it side to side.
I usually do stripes and I do one end, from the middle out. Then the opposite end from the middle out. That way I'm only rolling the stripe back off the plane, and then down onto the plane.
There's my 2 cents,
Fever
There's my 2 cents,
Fever
ON, CANADA
when you use the trim solvent, all is is is acetone at a higher cost. i find the best way is to have is on a flat and even surface. first, put your trim onto the main color, with a small over lap. what the trim solvent does is activate the glue. by aplying the trim solvent to a cloth and just going over the seam, the solvent will seep into the crack and the glue will set. one note, when using this, it really glues the two together for good, it's hard to take them apart without destroying them.
this also wooks great when you have that seam that keeps coming up on you all the time, it won't come up again, and yea, is also does a great job at cleaning up, especially if you used too much heat with one color and smeared it onto the next color, will clean it all up.
GB
GB
My Feedback: (310)
Great Cleaner
Originally posted by flytime56
this also wooks great when you have that seam that keeps coming up on you all the time, it won't come up again, and yea, is also does a great job at cleaning up, especially if you used too much heat with one color and smeared it onto the next color, will clean it all up.GB
I use a magic marker to make my trim alignment marks and it cleans those marks off. Plus any Lusterkote overspray :stupid: can be cleaned off the adjacent monkote with a Q tip and some Trim Solvent.
A bottle last a long time but I'll try Flap's suggestion of straight acetone next time.
Bill
It should work fine, expensive, but works fine.
You can buy the same active ingredient by the gallon for less money than that 4oz bottle will cost, home Depot, lowes, Probably Wall-mart too, ACETONE.
I was a firm believer in trim solvent, until I found RCU and picked up this as well as a lot of other tips.
PA
> Yes it works equally great on Ultrakote. <
Why would you want to use this when Ultracote covers itself smoothly, without bubbles?
Dave Segal
Dave Segal
