 SIG J3 1/4 question!? >
Old 09-07-2005 | 04:40 AM
Default SIG J3 1/4 question!?
Hello all,
I'm building the J3 from SIG, and i will install the twin 160 from magnum.
did someone have build this aircraft with this engine configuration and how large must be the thick spacer between back of the engine mount and the firewall for the prop to be just after the cowl?
thanks,
Old 09-07-2005 | 06:04 AM
Default RE: SIG J3 1/4 question!?
Measure the engine length, and lay it out on the profile view of the fuselage on the plans.
Dr.1
