Reload this Page >
GP Ultimate Decals
GP Ultimate Decals
Old 09-14-2005, 01:20 AM
srpvw
Default GP Ultimate Decals
Hello Everyone
I am on the final approach with my ultimate. I want to use the some of the decals that came with the plane including the large ULTIMATE! for the top wing.
What is the best way to apply them so that I dont have to worry about them.
I am covering the bipe in ultracoat.
Thanks Steve
Old 09-14-2005, 07:46 AM
DavidAgar
My Feedback: (108)
DavidAgar's Avatar
Default RE: GP Ultimate Decals
Check your instruction manual. Most of them can be applied using Windex sprayed on the wing and then once the decal is in the correct position, you can work out all the Windex from under the decal and in about 24 hours it is on for good. Good Luck, Dave
Old 09-14-2005, 11:55 AM
srpvw
Thanks Dave
There is nothing in the book at all I have heard about the windex I will give it a try.
Do you trim the decal close or just leave it as is
thanks steve
Old 09-14-2005, 04:30 PM
DavidAgar
My Feedback: (108)
DavidAgar's Avatar
Trim it as close to the edge as possible. Make sure that the entire surface is covered in Windex and then lay the decal in the Windex. Once you have it in place, gently push all the Windex out from under the decal, going from the center out and let it dry over night. Good Luck, Dave
Old 09-14-2005, 05:00 PM
srpvw
Thanks Dave
Steve
