canopy glue
NC
I need to remove a canopy that has already been glued down with canopy glue. Does anyone know if this can be accomplished without tearing up the model?
My Feedback: (27)
WI
Assuming you are talking about canoopy glue like RC-56, I would start by soaking the joint with water using a damp paper towel. Since the wet glue cleans up easily with water, this may soften the glue joints enough to remove the canopy.
NC
Thank you KROSSK. I will give that a try. I do know that the clean up on the instructions say that water is all that is needed to clean the excess glue off of whatever it is attached too.
