four star 60 wing
OK
Has anyone else had trouble with the dihedral on the four star 60? I have put two wing kits together and put them together just like the direction and plans say and i have gotten the dihedral wrong evertime. I even cut both wings in half and re did the dihedral guess i have to do it again.
How much flying experience do you have? If this is your second 4* and you got pretty comfortable with the first one, you might consider just building the wing straight with no dihedral.
OK
The result was a wing with anhedrial instead of diehedrial. It seems i get the top of the wing and the bottom confused. I even compared it to the blue print before putting the dihedrial brace in. It happened twice. What a stupid mistake. I have been building and flying for about 2years solid now. THe first plane flew 30seconds and the servo reversed itself. There were 3 other pilots who helped me preflight check the plane and they could not believe it when they saw the servo reversed.
