prop size
MD
im building a golberg cub and i need to order a prop tonight.any advice on prop dimensions,brand or type of material?clipped wing,.58 nitro mds.thanks
VA
All out performance should not be a factor with a cub, so prop type I believe is whatever you like. For that size engine, there are not many choices. I'd say 12-6 would be best, but if it's overpowered at all, you could use a 13-5 or so to get the noise down.
I would go with a lot pitched prop. So up your diameter and lower the pitch. It will keep the airplane
slower but still allow enough pull. Cubs were not designed to be fast. I always go with a small pitch prop
on an airplane that is meant to be "lazy".
