 WHAT PROPELLER SHOULD I USE? >
Old 03-11-2006 | 09:19 AM
My Feedback: (12)
Default WHAT PROPELLER SHOULD I USE?
I am building a Top Flight Contender. I will be installing a new OS .61 FX. I would like to use a 3-bladed propeller
because it will look more in line with the theme of the plane (NAVY).
The OS manual merely says: 12x6-8, 13x6-7. No mention of three bladed propellers.
I will be flying sport, no heavy areobatics or no 3D. More pattern type flying.
How about a couple of suggestions, from the RC crowd. I am rather new to RC, so I
need your input.
Jim
821369
Old 03-11-2006 | 11:59 AM
mscic-RCU's Avatar
Default RE: WHAT PROPELLER SHOULD I USE?
Zinger has a chart on their website. If my memory serves me correctly, I am getting old now, you drop the diameter and keep the pitch. Example: an 12x6 two blade is an 11x6 three blade. [link=http://www.zingerpropeller.com/_2_blade_.htm]Zinger Propeller Conversion Chart[/link]. Hope this helps.
Old 03-11-2006 | 01:04 PM
My Feedback: (12)
Thank You for your help. The link you provided, I have saved to "favorites". It is full of info.
Now to find a spinner. Zinger does not show any for 3 or 4 blade propeller in 2 3/4" size. I amy call them
to see if they have such an animal.
Thanks, again
Jim
821369
Old 03-11-2006 | 03:24 PM
mscic-RCU's Avatar
check out this link: [link=http://www.truturn.com/cgi-bin/store/agora.cgi?cart_id=%%cart_id%%&keywords=tt27&ppinc= 1aspinners160&maxp=30]tru turn spinners[/link]
Old 03-19-2006 | 04:29 AM
Banned
for a 60 engine, a 3 blade would be like an 11x6-11x8, 12x4, 10x5-8... for a typical 60ish size motor.
hth
Tim
Old 03-19-2006 | 10:25 AM
My Feedback: (17)
when going doen to a 3 blade, a good rule of thumb is down an inch and up in pitch. example: 12x7 2-blade 11x8 3-blade <-- this is what I used with my .61 FX. I also used a master airscrew prop[link=http://www.masterairscrew.com/GoCart/itemlist.asp?RootID=7016]Master Airscrew Prop[/link]
Old 03-19-2006 | 11:16 AM
Hello!
A start would be a 11x7.1/2-11x8 or 12x6 APC ...no 3-blade will equal a 2-blade prop
Regards!
Regards!
Jan K
