 TF dc-3 weight issues >
Old 03-13-2006 | 02:20 AM
splitzed's Avatar
Default TF dc-3 weight issues
hello, I am building the tf dc-3 and am worried about the weight it is going to come in between 12 to 13 lbs which is considerably heavier than the recomended 8 to 10 lbs. I am using Saito .56 engines which is at the top end of the recomended range. Should I be concerned?? Thanks TJ
Old 03-13-2006 | 10:01 PM
Default RE: TF dc-3 weight issues
From the examples I've seen of the Topflight DC-3, it's overpowered (from a scale perspective) with the larger engines. Given the size of the wing and the airfoil, I don't think you'll have any trouble flying it at 13 pounds. The extra weight will just contribute to a higher stall speed, so don't let it get too slow on final.
Tom
Old 03-14-2006 | 02:56 AM
splitzed's Avatar
Thanks for the reply Tom I will definatly keep the speed up!!
Old 03-14-2006 | 05:27 AM
Blue_Moon_'s Avatar
Dont you have flaps? 60degree of throw
Old 03-14-2006 | 11:18 AM
splitzed's Avatar
If anyone else is flying this plane can you let me know the weight it came in at and what engines you're using Thanks TJ
