4 * 60 wing attachment >
Old 12-10-2002 | 04:56 PM
Default 4 * 60 wing attachment
I am building a 4*60, great kit so far. I have a concern about the wing bolts. The instructions say to drill the hole then use a tap to thread the wood. Then apply ca to harden the wood. This seems like it would work for a while, but long term does not sound safe.
Anyone else every have any problems or experience with this?
Jeff
Old 12-10-2002 | 05:14 PM
Done it many times with many kits and not had a problem. I always use two bolts and the first sign that a bolt is going in - bottoming out - but not tightening up - -I fix it.
Old 12-10-2002 | 05:18 PM
Default wing bolts
Thats good enough for me! How do you make the repairs if needed?
Old 12-10-2002 | 10:26 PM
With a blind-nut (t-nut).
Old 12-12-2002 | 05:03 PM
I used a couple of brass 1/4-20 inserts with 3/8" external wood cutting threads. Works great.
