Topflite Spitfire???
I am currently building the spitfire. What I can tell you is the kit is good. However, certain points must be considered:
If using retracts, must build up the area arount the wheel well.
Also, the CA hinges go into only 1/4" balsa. I recommend adding support to the area behind the hinges.
These are my recommendations at this point.
