 Help in Building- Cleaning >
Old 06-17-2006 | 02:34 PM
Default Help in Building- Cleaning
Hi I have built a few planes and by time I finish, it already looks old because i keep dripping glue or epoxy on the finished wings, fuselage etc.
What can i use to clean the glue when i spill it. Is there and epoxy thinner, or ca or something to keep the plane clean. Or should i just find a coating to keep on it.
please send reply to
[email protected]
Old 06-17-2006 | 02:49 PM
Campy's Avatar
Default RE: Help in Building- Cleaning
Acetone will remove CA.
Alcohol will remove epoxy WHILE IT IS STILL FRESH (wet). Once epoxy dries it is a different story. On a film covering it MAY pop off (about a 50/50 chance ).
What I do is have a building area AND a covering area. Once a part is covered it is moved to an out of the way location until I am ready to do a final assembly of the plane.
Old 06-17-2006 | 02:54 PM
Thanks for the quick post, I will definitly pick some up before i start my next model, either an Extra or a P51 I've always wanted to build.
Lar
Old 06-18-2006 | 08:20 AM
Acetone will also loosen the covering seams. The best way to remove glue from a finished frame is to not get it on there to start with. Work more carefully, slowly, and neatly. Wipe any spills IMMEDIATELY.
Dr.1
Old 06-18-2006 | 12:18 PM
Yea, well there in lies the problem. I do wipe it up, the question was what do i use to wipe it up with...
I did receive answer tho.. acetone for ca, alcohol for epoxy, that should fix my problems..
thanksl
larry
Old 06-18-2006 | 08:23 PM
blw's Avatar
blw
CA remover (uncure) worked great for a big CA spill on Ultracote. It had been there for a couple of months before I used it. Came off instantly.
Old 06-18-2006 | 09:57 PM
Thanks, Is that the same as the debonder?
Old 06-18-2006 | 10:45 PM
Campy's Avatar
Yep. The prime ingredient in both is acetone. You can pay about $5.00 for a quart of acetone or about $5 - $7 for a 2 oz bottle of uncure or debonder.
As DR1 stated, be careful around the seams of the covering and decals.
Old 06-19-2006 | 12:23 AM
Will do thanks for the help, maybe my next plane will stay looking clean..
Old 06-19-2006 | 08:28 PM
blw's Avatar
blw
I didn't try pure acetone but I did use something with acetone in it. No results. The debonder worked fast. I've had the bottle for a couple of years with plenty left.
