Covering and Canopies >
Old 12-28-2002 | 11:33 PM
Default Covering and Canopies
Hi guys-
I'm working on my Laser 3D and am ready to start covering...I think. What's the standard order of installation? Install the canopy, then the covering? Or the covering then the canopy? My Pizazz has the canopy over the covering and it's really only tolerable in terms of its looks. So, should the canopy go over the covering, or should the covering go over the canopy? Well, the edges of the canopy anyway.
Thanks!
Reid
Old 12-28-2002 | 11:38 PM
my suggestion
covering then canopy
after covering is done , glue your canopy on the covering with a canopy glue
Old 12-29-2002 | 02:56 AM
I usually cover first
Old 12-29-2002 | 05:16 AM
Ok, I'll give that a try.
Thanks guys!
Reid
Old 12-29-2002 | 07:37 AM
CaptKAOS's Avatar
My Feedback: (7)
You could use 1/4 inch striping tape around the edge of the canopy. This will make it look better as well as help seal out the oil from the engine....
Old 12-29-2002 | 09:23 AM
in fact, I usually use a trim line from the matching color of the covering to give a more "finished look"
If you try to iron with the canopy in place you have also a risk to ruin your canopy with the eat of the ironing tool
Old 12-29-2002 | 03:13 PM
My Feedback: (26)
Default Covering or canopy
Cover then add the canopy last. You might want to try someting I just did on a 4 * 60. Painted the inside of the canopy black then used matching Ultrakote strips to trim out the canopy frame. After the frame was trimmed out, I used thin black trim tape to mark the canopy seam. Be careful when you cover a canopy with covering. Use just enough heat to activate the adhesive, you don't want to melt the plastic. Little bit of care and you will be pleased with the result. Hope this helps. BTW read this tip a long time ago on the old RC online.
