pushrod help >
pushrod help
pushrod help
Old 01-14-2003 | 01:14 AM
Default pushrod help
I need to attach a separate pushrod to each of the threaded rod coming from the split elevator on a F4 Phantom. Then solder it into a sleeve with the third rod that goes to the servo.
I dont solder.
This is a critical connection and don't want it to fail ever, but need a better idea. Would 30 min epoxy work? Is there some kind of dual clevis or such a thing?
Old 01-14-2003 | 01:54 AM
AAAHHH,........ ya ought to learn to solder, its easy, works great, cheap and handy for lots a stuff.
Old 01-14-2003 | 04:01 PM
MinnFlyer's Avatar
Very true. A small investment at WalMart can save you hundreds if you ever need extentions or Y cords. And it ain't rocket science.
PS and no... epoxy is not a good idea.
