Extra 300S cowl
BC, CANADA
Its a builders kit, I think I just found the problem. After I cut the bottom of the cowl out for the venting, it had enough flex in it to go over the fuse.
BC, CANADA
Thats what I did too but I was trying to get it on before I did the bottom cutout on the cowl. It is tight tho. I just got the Saito 100 and don't know yet if I'm going to ge able to conceal the muffler in the cowl, I have it mounted sideways, the 100 muffler is quite a bit bigger then the 91.
