Dynaflite Decathlon >
Dynaflite Decathlon
Dynaflite Decathlon
Old 02-13-2003 | 09:12 PM
Default Dynaflite Decathlon
Getting ready to put together a Dynaflite Decathlon. Planning G38 for power. Any pros, cons, building tips, pitfalls, mods and or etc would be appreciated.
Old 02-14-2003 | 12:47 PM
Bob,
Good choice all around. Have fun building!
A couple of comments --
Be thoughtful of the weight at all times, particularly in the rear. Mine has a Quadra 42 in the nose and it still took dead weight on the firewall to achieve balance (Grrrr!).
I redesigned the struts to be functional. There is an aluminum strap across the belly behind the gear, then 1/16 x 3/4" aluminum flat bar out to the end (leading strut only, kit provided wood strut in the rear). #8 bolts at the ends. The flat bar is surrounded by balsa for shape and light glass/epoxy for stability. I also added the jury strut support out of respect for scale.
I didn't like the kit's tailwheel design so converted to a plastic Klett scale-like design. That has worked out well.
If I were to do it again and was very energetic toward having a scale bird, I would completely redesign the wing joint and attachment to the fuselage. Rather than butting the wing halves together, I would butt them to the fuselage sides. This would require a simple and light shear guide at the root and good functional struts. It would be lighter and allow for a proper through the roof sky-light as on the full scale machine.
Be ready for some real balsa carving. How therapeutic!
Good luck.
Bedford
