 linkage sizes? >
linkage sizes?
linkage sizes?
Old 03-31-2007 | 05:09 PM
iraqvet's Avatar
Default linkage sizes?
I'm trying to determine which linkages go on my 4*60 ailerons. The kit has a 4-40 set for the ailerons and a 2-56 set for the rudder/elev. but I don't know which is which. Are the 4-40s the larger diameter linkages??
Old 03-31-2007 | 05:20 PM
Default RE: linkage sizes?
Yes. The 4-40 is really a #4 screw size, with 40 threads per inch. The 2-56 is a #2 screw size, 56 threads per inch (56 TPI). The bigger the number, the bigger the screw.
Mark
Old 03-31-2007 | 09:05 PM
horace315's Avatar
My Feedback: (15)
i would think the bigger rods would go on the rudder/elevator.
Old 04-01-2007 | 11:41 AM
Gringo Flyer's Avatar
My Feedback: (18)
ORIGINAL: horace315
For a 60 size plane you will want to put the 4 40 (larger) linkages on the elevator and rudder. You could probably get away with 2 56, but in general each aileron will come under less stress than the rudder and elevator so smaller linkages can be used on the ailerons.
