AAargh! Monokote and contours!
I finally got a nice contoured wingtip with Monokote and ruined it when I applied trim. THe pattern is like a pitts special and the stripes that went over the wingtip did not go well. I had to cut and overlap them and I still got wrinkles. Is painting the answer or is there a technique that works?
Jeff
Jeff
ON, CANADA
paint for me on monokote doesn't work. after some years, in the hot sun, it just flaskes off.
when i do wingtips, leave a lot of excess material and just pull hard on it, and use a heat gun. for the trim, i would say use a heat gun also. some desings on wing tips just don't work well, well that's in my case, so i design something else.
that monokote trim stuff isn't good for anything round, only flat surfaces.
use good heat, and when applying, just pull it good and tight.
good luck
GB
good luck
GB
TX
Hi jwc, when I cover with Monokote or Ultracote on the corners or wingtips,I'll leave a couple of inches of covering to hold on to and long enough that the heat doesn't cook my fingers,generally I run the heat up to 400 to 425 degrees,the covering will really stretch nice around tips,after I have the covering shaped around the tips then I'll tack it down to the wood,I prefer Ultracote,but each to there own, covering is easy but you might practice on scrap wood to get the hang of it.
OH
You know, I've been using monokote for some twenty years now. The last time I used it it wouldn't shrink and compound curves were near impossible to do. I switched to Oracover on the one I'm finishing now and love the stuff. Oracover makes Ultracote and is about 4 bucks a roll cheaper. Thanks Minnflyer for turning me on to this stuff.
